805moparkid
Slant and AFX Guy
so 81%
and now you tell what the means... and how it relates to what i need
lol:wav:
so 81%
Damn,this is deeper than I ever imagined !! I just want an awesome cam for street light to light confrontations and trips to the strip !!I had one of Mopars 528/278 (?)cams that was fun,but the gear shattered on me !! I ended up with a 468/276 that was still peppy enough,I just want to take this motor a step or two higher !!Maybe even look at a Paxton ??
at what it takes to feed higher rpms...the higher the exhaust flow there needs to be. ratio is dependent on lots of variables..maybe chamber/burn efficiency/comp ratio..you can cam around this.
but they basically have a rule of thumb, well some do..I'm in the 67-75% for NA club.lol
Its what split pattern cams work around too
There is a point that where if ur not too careful...you'll over scavenge and pull raw fuel right out the exhaust.
Price doesn't sound bad !!! To my ignorant mind,the lift and duration numbers don't sound too bad either !!But again,what do I know ??
Hell,Daytona Beach, I could just drive up in person !! I may just copy that info and go talk with them ! Those numbers may just work for my application !!
I take you've decided to forego the option of a turbo, for now....
That cam would not be necessary with a turbo motor, and in fact, would not work well at all with boost.
You need to think twice before you go down this N-A road; you're giving up lots of horsepower and getting in return, a lumpy idle, poor driveability around town, probably significant gas mileage, and the necessity for a rear axle ratio that will not work well on the highway.
And, in the end, you'll end up with performance far short of what boost can provide.
But, it's not MY car; you need to do what makes YOU happy, and I need to butt out...
I'm going to do that; this is not "my call..."
I apologize for my overbearing, CONTROLLING, obnoxious comments...
Dunno what got into me...:sad11:I'm sorry...
i would bill but i am really using this motor to learn what the needs of my "Stupid Slant Project" as Rob (SS) calls it lol...
but just so you know im planning on boosting the 63 dart with a 6 for a really good milage driver...
Well, tthe IMPORTANT thing is to have FUN!!!!
If you're having fun, then you're doing it right! :cheers:
I just get carried away sometimes... forgive an old man in his dotage...ops:
Aren't our lifters the .904 already ??
ok so i found the goddess of cams from oregon cams (ken)... you ready???
408 lobe lift x 1.4 rockers = .571 before lash
252 duration @ .050, 292 adv
the kicker is that it needs a 1" lifter lol...
so now the next door opens and finding a compatible 1" lifter...
ok talked with chris at Engle... really good guy!
he said the best he can do would be his KV-3
its a .383 lobe or .536 before lash with 253 duration... about 180 bucks
now calling oregon lol
