fishy68
Tyr Fryr's Inc.
If your using a Molnar crank what rod bearings are you using? Dropped the crank in my 408 today to replace the broken junk Eagle crank and I tried to use Speed pro (Federal Mogul) 8-7125CH chamfered bearings but they don't have enough chamfer. I used them on the Eagle crank and they worked fine but it seems the Molnar has a little more radius. Has anyone modified their bearings for more chamfer? I've heard of it being done but have never had to do it nor seen it done. What do you use?
