will it fit ? radiator 2949069 (abody year 1969 ?!) in early Barracuda 1965
lilredridinghoo
lower saxony
i´ve tried to search for the answer, but havn´t found a proper answer...
i´m just thnking of exchanging my modern aluminium radiator (which works good, but looks a bit like an alien in the engine bay) with an original Mopar radiator i just have seen pictures of a few days ago, and it would be available for a fair price ... but i´m not sure, whether it will really fit boltwise
the part number i have found reads 2949069 - so it should be from an 1969 V8 Abody i guess.
In- and outlet are located the same like my long gone orig early radiator (as far as i remember)
thanks for any hint you can give to me
Pre 70 should work as long as it has the drivers side lower hose outlet. 65'
Does the width of the radiator match the hole as I believe 16" or 22" were available.
just done some measurement on my fish radiator hole is approx 23" width (mounting holes somewhat 24 1/2")
the aluminium radiator i´m currently using shows a total hight of 21 1/4" and does not interfer with the hood.
guess i will give it a try
