Will the 505 cause a volcano in Challis, ID?
IQ52
Idaho
The geologists are about to discover that Pop's 440 was causing the swarm of earthquakes here in Challis, ID. What if the 505 causes a volcano?
funny, that's what I thought, when I heard of the quake near Challis.
I felt it here in N Idaho. lol
One of Jim's less interesting threads...
Very acccurate observation. Pretty darn boring (tedious dullness) up to this point.
We introduced some antifreeze into the closed circuit water system that supplies the absorber for the dyno (BIG MISTAKE) and it foamed in the absorber. Looked like someone put dishwashing detergent in an automatic dishwasher. Thats all cleared out now after flushing the whole system and the dyno is operating as it should again. Could have some results this weekend.
This thing really could use a cam, an intake manifold and carburetor. Sorry guys, this isn't for an A-body. It's for a street driven 1st gen Challenger.
440 Source 4.25 stroke, 4.350 bore 505ci
10.4:1 compression, 91 octane
750 Holley
Edelbrock Torker II
RPM heads w/ some tweaking
Comp Cams custom hydraulic roller
The first tq & hp columns are with the engine as above. Second we put on an Edelbrock RPM Performer and third we added a Q950 Quick Fuel
RPM.........(1st TQ.......HP)......(2nd TQ.......HP).......(3rd TQ.......HP)
3000...............521.....298.............538.....307............539.....308
3200...............532.....324.............554.....338............568.....346
3400...............571.....369.............599.....388............599.....388
3600...............579.....396.............597.....410............609.....418
3800...............579.....419.............600.....434............611.....442
4000...............580.....442.............599.....456............605.....461
4200...............582.....465.............589.....471............595.....476
4400...............586.....491.............584.....489............596.....499
4600...............600.....525.............592.....518............598.....524
4800...............600.....548.............586.....535............594.....543
5000...............592.....564.............589.....560............593.....565
5100...............591.....574.............584.....567............594.....577
5200...............586.....580.............582.....577............589.....583
5400...............566.....582.............566.....582............574.....591
5500...............559.....585.............556.....583............570.....597
5600...............552.....589.............545.....581............556.....593
5700...............538.....584.............537.....583............548.....595
5800...............537.....593.............526.....581............535.....590
Average TQ/HP...572/480..................577/483...............586/490
The RPM Performer shifted the torque peak 1000 rpm lower.
Is config 3 how the engine will go in the customer's car? Or back to the 750 and torker intake? Regardless, that's still gonna be one movin' E body...or at least shredding tires...
A random question. What would it cost for someone like you to build one of these for a customer?
This one is for a customer. Please understand that these engines are the blink of an eye away from 700 HP. With a camshaft, intake manifold, and carburetor swap and some additional head work, some crazy power is available. With that in mind, a turn key dyno'd engine is in the $14,000 range. Each one is designed and priced on an individual basis.
Unless the customer changes his mind, configuration #1 will be what he gets. The idea was to use as much of the owners original 440 components as possible. The engine came to us with Harland Sharp rockers, a Crane cam, $700 Crane hydraulic rollers, RPM heads and the Torker II and 750 Holley. The combination right now could use a bigger single plane. I'm trying to justify trying the Edelbrock Victor we have laying on the shelf.
So we tore the darn thing down and fixed it. Long story I'm not going through tonight. Here it is, still on 91 octane with the Torker II and his 750cfm Holley. Two back-to-back pulls.
RPM............TQ/HP.............TQ/HP
3000..........513/293..........518/296
3200..........534/325..........548/334
3400..........585/379..........590/382
3600..........597/409..........602/413
3800..........599/433..........603/436
4000..........609/464..........605/461
4200..........608/486..........608/486
4400..........610/511..........609/509
4600..........613/537..........613/537
4800..........619/565..........624/571
4900..........622/580..........626/584
5000..........621/591..........621/591
5200..........617/611..........619/612
5400..........613/630..........610/627
5500..........602/630..........607/634
5600..........595/635..........601/640
5700..........592/643..........588.638
5800..........578/638..........586/647
5900..........573/643..........679/650
6000..........572/654..........564/644
6100..........566/657............na/na
