Windage Tray location up/down:
I am installing my windage tray on my 340/420 bottom end. I now have the ARP main cap studs that have the 3/8”-24 mounting studs for the tray. These are fully threaded so that the tray can be moved up/down to fit under the pan.
My main concern is, do I need to mount the tray as close to the crank/rods that I can, or as far up/away from the crank that I can?
Either way, it looks like it will be a little higher than with the OE main cap bolts with the tapped holes.
Thanks!
Thanks!
