Window question
Discussion in 'Mopar Body and Trim' started by dartboy73, Aug 8, 2018.
  1. dartboy73
    dartboy73 Well-Known Member
    118
    3
    May 13, 2006
    Local Time:
    4:10 AM
    Installing the glass on my 68 fastback barracuda there seems to be a small hole on the inside top middle of the door that holds the windows together. I was told is a specialty bolt can anybody point me in the right direction to what I need?
  2. Murray
    Murray FABO Gold Member FABO Gold Member
    376
    126
    Apr 19, 2010
    San Jose, California
    Local Time:
    2:10 AM
    This is odd- your hole appears to be about 1" lower than mine. This hole is capped by a rubber, interior color plug. The purpose of the hole is to allow access to an allen head bolt in the vent wing assembly which is used as an adjustment. If you have changed the interior color, then you will need to paint that rubber cap to match. Good luck.
  3. Cuda Al
    Cuda Al Well-Known Member
    400
    237
    Oct 21, 2007
    Lompoc, CA
    Local Time:
    2:10 AM
    The 67 used a philip screw and was higher (about an inch) than the 68, the 68 has a screw (allen I think) that you access through that hole.
    edit: I just looked at a picture of my 67, it is the other way, the 67 is in the location as pictured.
    Alan
  4. Murray
    376
    126
    Apr 19, 2010
    Local Time:
    2:10 AM
    Thanks Alan, interesting. Mine is a '68, is 1" higher and is an allen. I guess '67 is a little different.
    • Agree Agree x 1
    • Murray
      376
      126
      Apr 19, 2010
      Local Time:
      2:10 AM
      Maybe Dartboy has a '67 door.
      • Agree Agree x 1
      • HemiSSDart
        HemiSSDart Dartus Interuptus
        665
        338
        Feb 20, 2013
        Illinoisy
        Local Time:
        5:10 AM
        That is why I keep telling anyone who is selling doors to tell me what year the door came off of! 67 is unique, 68 is unique, 69-72 are similar enough to not worry about. Darts and Barracudas changed the same things.
      • HemiSSDart
        665
        338
        Feb 20, 2013
        Illinoisy
        Local Time:
        5:10 AM
        The wing window handle tells me it is a 67 door that he has. It changed in 68 and remained the same afterwards.
      • dartboy73
        118
        3
        May 13, 2006
        Local Time:
        4:10 AM
        So it's a Phillips head screw that goes in there? Any idea on length?
      • Murray
        376
        126
        Apr 19, 2010
        Local Time:
        2:10 AM
        OK, pictures help. This is my '68 cuda, yours should be the same or similar. We are looking at the right side. On my car and on your car- that hole in the door allows you access to the allen bolt seen here, or maybe on your car a phillips screw. This screw along with others allow you to adjust the position of the "A" frame to the body/ weatherstrip.If I were to put an allen wrench through that hole to make an adjustment, the allen bolt itself is about 1 1/2" inside the panel. Hope this helps. 100_2402.JPG 100_2403.JPG
        • Like Like x 1
        • Murray
          376
          126
          Apr 19, 2010
          Local Time:
          2:10 AM
          OK- one more time, here is an example of late '68 vent wing handles. 100_2405.JPG
        • Cuda Al
          400
          237
          Oct 21, 2007
          Lompoc, CA
          Local Time:
          2:10 AM
          Either this 68 is an early car with 67 parts or the door(s) have been replaced with 67's.
          One would assume if the vent wing lever is also 67 the frame is as well.
          That being said he just needs a screw that a 67 would normally have.
          What is the build date on this car?
          Do the doors match?
          Alan
        • Murray
          376
          126
          Apr 19, 2010
          Local Time:
          2:10 AM
          Alan, I agree. These '67 parts can still work. Only if we want to be "correct"would we want to replace the whole door.
        • dartboy73
          118
          3
          May 13, 2006
          Local Time:
          4:10 AM
          The drivers door is a 68 and passenger appears to be a 67 no big deal it's a slant 6 with a gen 3 hemi swap done on it
        • Cuda Al
          400
          237
          Oct 21, 2007
          Lompoc, CA
          Local Time:
          2:10 AM
          I will get the information on the screw this evening.
          Alan
