window trim
mjs69gts
madison wi
my right rear glass chrome piece fell off the glass whats the best adhesive to hold it in place? its the trim between the front and back glass.:burnout:
The chrome division moulding between the 2 side windows is held on with a thin strip of flat butyl rubber stripping. I can't recall exactly what it is called but I bought a roll of it from Layson's years ago and did all of my cars with it. I will check at the shop tomorrow and see how much I have left if you'd like. If I have enough to do yours I'll gladly send you a strip. I'll message back tomorrow, Geof
I put new felts in mine and glued the chrome to the glass with the same black 3M adhesive that I used on my trunk seal and door seals. 3M #08011 I believe.
i have a tube of the 3m stuff, i was just seeing if there is other stuff to use.
i want to thank geof he sent me a strip pf adhesive for my window trim and when i asked him how much he just said a thankyou is all i need. so now im letting everybody know about it thanks again geof.
