Windshield Pillars?
coalman
Texas
On a 66 Dart GT, what inside pillar moldings are interchangeable from previous years? Thanks
To be exact, only 66 will be exact, they are plastic. Now will fit, sort of, 64 and 65 Abody. These years are steel. I have a steel set that I will be using, don't know how they will work out yet. The 66 ones seem to be a dream to find not busted up.
Are you going to use your metal ones on a 66??? There is a bone yard not too far from here that looks like they have a 65 with them intact. Thanks for your reply...
I am going to use the metal ones on my 66. If I was you, I would get those while you can. I think the ends, by the dash are different, plastic covers more. BUT im still going to use them because I have not been able to locate a good set of 66 pillar covers.
65 and 66 are plastic. 63 and 64 are steel. Steel ones need the rubber piece at the bottom that locks into the dash.
I am going to make a set using fiberglass. The end pieces The 65's I looked at had steel. That is good info, but still made out of unobtainium. Thanks:cheers:
