rednesss
Does anyone have any wisdom about putting an intermittent delay on the wipermotor? I have the variable speed switch and motor.
does anyone have any wisdom about putting an intermittent delay on the wipermotor? I have the variable speed switch and motor.
I used the wire that originally went to electric wash pump to get a 1 push equals 1 sweep wiper. This does not work in later model systems where wiper motor reverses to park and/or switch rotates to low speed when pushed.
But putting a momentary switch connected to the same circuit as the low speed of the wiper switch does.![]()
You just have to hold the momentary switch down long enough to get past the park action, and when you let go the wipers will continue one sweep and then park again.
I'm eventually going to do this on my car with the switch coutersunk into the thumb end of my Hurst T handle.
They also make aftermarket adjustable intermittant wipe relay kits in various forms like this.
https://www.quasarelectronics.co.uk/Item/smart-kit-1093-intermittent-windscreen-wiper-controller
I also saw where you can get the intermittant module out of the wrecking yard and wire it in to our wiper systems using our original multi speed switch.
One real easy way is to use the low setting on the original switch for intermittant wipe, and the med and high as normal.
Then the speed of the intermittant wipe can be varied with an added rheostat. (but I don't like the added part of doing it that way)
I will just put together the one wipe button or turn the low speed into intermittant with a set time delay.
Instead of low, med, high, I'll have int, med, high and I think that should be fine, but either way I want the one push one wipe on the shifter handle.
How would you wire up the momentary switch? Just "T" into the "A" post?
Does anyone have any wisdom about putting an intermittent delay on the wipermotor? .....
The spare motor I have reverses to park. I'm wondering if the one I have installed in the car is the same or is different? I wasn't aware that some reversed and some didn't. Guess I'll have to go see what it does.
How did you wire yours up? Which wire did you splice? The "A", "F1", "F2", ????????
I just went out and checked, when it's running it spins counter-clockwise, when the switch is turned off, it rotates clockwise to park. Does that mean my dreams of intermittent wipers are not going to happen?
I've been busy working on other things on the car. I'll make it back around to this issue shortly. I wish there was a more plug n play method.
