69413valiant
I would like to wire my Holley black wlectric fuel pump to my ign key. I want to get rid of my toggle switch. Where is the best place to do this? I checked the ballast wires and thought about there but I'm not sure.
off the fuse box there is a key on power, leave the toggle on it also so you can shut it off if the need arises with the key on. i usually use a relay also.
