Wiring wizard lots of things working now
gdizzle
los angeles
66 dddart L6.
Spent most of the day wiring . Got my 2 new gauges wired up, including dimmable back lighting. Tried to replace the passenger side Door jamb switch. the new one i got seems slightly longer than the old one, afraid it is pushing on the inside of the door jam now. But also not sure how to connect it, all I have is a bare yellow wire. It looks like it needs to be a Bullet style connector? Any ideas where you find that?
Also the back side (connector side) of the new jamb switch is hitting the cutout in the panel? funny cause the old one I pulled out had been bent down to avoid the obstruction??
There is just one connection to the door switches..... the switches provide the ground to the dome light (via yellow wires) while +12v is fed into the other side of the lamp.
Can't help with the rest of the questions....
