won't cut off
I've seen this, not always the same fault. For some, and I don't recall what brand/vehicle, Wires to/at the starter were shorted together. Back feed kept it powered up.
You'll likely go under your dash first to find a white harness connector from ignition switch to cars harness. You might find a meltdown fault right there. Good luck
