highflyer
im thinking of going with this cam 1973 .360 03 over standard compression.Anyone ever use it..ill be using the 901 16 springs retainers and locks...cloyes gear and chain..j
Great cam but I would probably upgrade my valves to 2.02/1.60's to take full advantage of that cam. The 360 can breath quite a bit but is limited by the small valves.im thinking of going with this cam 1973 .360 03 over standard compression.Anyone ever use it..ill be using the 901 16 springs retainers and locks...cloyes gear and chain..j
I run that cam in my truck. You're better served running the Summit brand billet roller chain set and a tensioner. The Comp stuff isn't that good so I'd run a tensioner regardless of the chain you choose to run.
No problem with asking... There's a big difference in personal experience from a guy with one or two builds in his history, and one with lots of them over decades. Also to be clear I didn't say they were trash and steer clear. I said they're not that good and run a tensioner with whatever [he] chooses. The $30 tensioner makes a $25 chain keep pretty decent cam timing over time in a mild to medium performance build. Or you can just buy the $50 timing set. Or do like me and buy the better timing set and the tensioner...lol.
I've used Comp products and they are generally good value and good quality. However - the timing chains at least for Mopars have historically for me never been really good value. The are, IMO, sloppy from the get-go, stretch quickly, and stretch a lot. I've used timing sets from Comp, Sealed Power, Cloyes, MP, and Summit over the years. Cloyes true-roller used to be the best chain - but that quality level has gone down at least IMO over the years as they re-sourced the chains themselves and tried to stay competitive. The Summit billet set is the best bang-for-the-buck based on my experience. I don't know who makes the parts - I'm sure they are overseas stuff - but they are tight when new and only move a little once they run a little even when pulling a roller cam. I've found that out when I tear down for cam adjustments or just to swap cams again.
Gotcha. Their cams are fine and I run a lot of them. Their timing sets IMO are not anything I'm keen on running.
