If it ts just at the top of the dipstick most likely it is condensation and you just need to take the car out for a nice long cruse to drive the moisture out of the oil, but if the dipstick is like that all the way down, do not drive it, most likely you have coolant in your oil and driving it that way you run the risk of bearing failure or even having a bearing seize!
Nuttyprof
