Which should be done regardless.Nice, but I see that it requires the Level 1 Motorsports chassis stiffening kit installed prior to installing the perimeter frame, more $$$. Still I like the idea, and with the ever growing popularity of modern powertrain swaps I expect it will be well received.
For the record..."..Frame requires substantial cutting, welding and grinding to install. A fully illustrated instructional manual is included and available for download on our main web site.Nice, but I see that it requires the Level 1 Motorsports chassis stiffening kit installed prior to installing the perimeter frame, more $$$. Still I like the idea, and with the ever growing popularity of modern powertrain swaps I expect it will be well received.
You are looking at material costs alone before even starting to make the pieces. You need to break it down into cost per piece. They can probably get 20 sets out of that sheet of 12 guage, and probabaly 2 or 3 top pieces out of a sheet of 18 guage. Not counting labor, you're probably looking at about $100 est. in material. A good metal man could probably whip it out in 2 hrs. if he has the schematics already.Have you priced a sheet of 12 ga sheet steel lately?
$189 for a sheet.
Now add the labour which is likely near 4 hrs for this. At a shop rate of $50 (likely higher) unless workers are being paid with peanuts.
$200 for labour
So lets say we already have $300 invested in labour and materials.
Who designed this?
Now if they could manage to make these in bulk the price would be reduced because the machines would be setup already and they could be spit out quicker.
But we are in the mopar world and we all seem to want everything for free, or close to it.
They likely have a very limited market because we all know not everyone will swap to a newer drivetrain.
Might sell 500 of these over 10 years. Making one kit every 3 months does not make it cheap. If they could sell 1000 a month for 3 years it would make it cheaper.
I get a half sheet of .019 cheaper 70.00But that's $189 for a 4 X 8 sheet right?
Agree - If they could build it with a smooth expanded horseshoe shape that blended easily with factory pans, it may be worth looking at.Looks terrible, could fab something much nicer. That looks like a section of a ribbed trash can
Yep... Upsell, Upsell, UpsellFor the record..."..Frame requires substantial cutting, welding and grinding to install. A fully illustrated instructional manual is included and available for download on our main web site.
You MUST install a USCT Motorsports Level 1 Chassis stiffening kit (frame connectors and torque boxes) before installing the Transmission Tunnel Perimeter Frame. The frame connectors and torque boxes tie the factory unibody together and work with the Perimeter Frame to make your car strong and safe when removing the OEM factory torsion bar cross member center for transmission clearance.
Requires a Cross member (not included) for your specific transmission. We have them for the 727, 518, NAG1, HP70, T56 Magnum and a universal cross member, call for other applications, we will help you out."
