Zero deck questions
MOPARoldtimer
Banned
California
Let's say you have a typical, stock, low-compression (8.2:1) 360 with "J" heads from the smog years.
Roughly how far below the deck are the pistons at TDC?
And how much would it raise the compression ratio if you were to substitute zero-deck pistons, assuming you made no other changes?
And how about the same questions for the low-compression 440?
