I pulled the engine out of my dart last week with the transmision, without dropping the center link, and without issue. It is just getting the angle correct, and a little bit of rocking as you start to pull it. The exhaust has to be dropped out from undre the car. Starter removed, 90degree filter adapter, exhaust manifolds, z-bar, etc. The driver's side exhast manifold wouldnt come out, so I just let it lie on the steering box when I removed the engine/trans.
The only hang-up I had was the Hurst 4-Speed shifter bolt-on adapter got hung up in the tunnel on a seam, took a pry-bar to drop the end of the transmission down a bit and it came right out.
