autoxcuda
- Joined
- Apr 6, 2007
- Messages
- 9,519
- Reaction score
- 5,043
Ok finally got the 416 motor running yesterday... Yessssss!
I bought the block on April 17, 2010. So about a year for this motor project. But really more than just a motor project....
Motor's is really nice. Revs pretty quick for a 4" stroke too. The idle and sound of Comp 274S mechanical cam seems like a good compromise for street and track car I was looking for. I'll report more later when we take it on the first drive. Troy Bray that used to be with Westoaks MP made this deal happen. He guided the whole motor built, ported the heads, has great fabrication skills.
Now to get ready for Spring Fling Speed Festival on April 14, 2011. It our track day out at the Willow Springs big track (loooong straights)
Basics:
ENGINE (as of 3/27/2011...)
COOLING SYSTEM:
EXHAUST
TRANSMISSION
Basics:
•SHORT BLOCK: ‘69 340 block, now .030 over. Scat cast crank kit from Brian @Indio Motor and Machine.
•BLOCK MODS: Oil passages smoothed and ported to reduce turbulence/cavitation and help flow. Valley smoothed and cleaned up to help oil drain-back. Water jackets/passages meticulously picked clean of rust and slag.
•OIL PUMP: Melling high volume. Passages smoothed and matched to rear main cap.
•HEADS: Edlebrock. Full ported, intake and exhaust matched, combustion chambers matched to block,
•VALVE COVERS: Old Cal Custom finned ($40 swap meet) with steel core MP gaskets for good no leak and removable seal
•CAM: Comp 274S soild. .502/.511, 236/242 @.050
•ROCKERS: Comp Pro Magnum steel rollers.
•INTAKE: Mopar M1 Single plane, changed to squared carb flange, cleaned up plenum, port matched and indexed.
•CARB: Demon Silver Claw 750 cfm advertised. Firesleeve on pump to carb 3/8" fuel lines
•FUEL LINE: 3/8" sender and 3/8" body fuel line. Firesleeve near headers.
•IGNITION: MSD E-Curve distributor
•OIL PAN: Milodon Road Race/Pro Touring pan developed by Milodon from this project!
•WINDAGE TRAY: Milodon with Milodon main stud kit
•BOLTS AND STUDS: Milodon Made in USA all in house. Heads, Mains, Oil Pan
COOLING SYSTEM:
•WATER PUMP: Milodon aluminum
•RADIATOR: Champion 4 core
•T-STAT: Milodon brass 160
•FAN CLUTCH: Hayden #2765 (short 3 5/16" mounting)
•FAN: MP viscous fan shortened 1" around
•FLUID: Distilled water, 2 bottles Justice Brothers Radiator Cooling System Protectant with water pump lubricant, 1 bottle Justice Brothers Super Radiator Cooler
•FAN SHROUD: Need to make. Both stock 67-72 ones will not fit with Champion 4 core
EXHAUST
•HEADERS: TTI 3/4 stepped for best ground clearance. Port matched, ceramic coated outside, thremal barrier coating inside. Best quality.
•EXHAUST: TTI X-pipe with Super Turbos 2 1/2"
TRANSMISSION
•TRANS: 727 Torqueflite, TCI shift kit, Type F fluid, will hold gear, can downshift, bang-screech
•SHIFTER: Worn beat-up B & M Quicksilver that came with car, ratchet action, sometimes a pain
•CONVERTER: 2600 stall and fins modded to get some engine braking.
•TRANS COOLER: All hard lines. 10x6".
