A while back Revhendo showed some pics of brake lines that he had fabbed up. They looked really good. I had always just eyeballed the bending of mine, sometimes with bad results needing to start over. Rev suggested using a wire coat hanger to mimic the required shape and fine tune it a little as you go. Got to say that method worked really well. Made forming the lines from master to prop valve easier and the result looked pretty good.
Thanks again Rev for the great tip! :-D
