Post your wheel and tire combos.
All I gots are some small bolt Center Line rims. I haven't a clue what the backspace is. They were on the car when I bought it.
15x4" front with G78/15 bias ply.
15x10" rear with Mickey Thompson 28x13.5x15 ET/Street.
At one point there were Goodyear front runners on it as well as some McCreary dirt track tires on the back.
The car was mini tubbed and the wheel wells stretched to fit. I haven't taken any new pics in years, so what I have has been posted before.
Wylde1.
heres my 74 dart sport with its new jegs auto drag knock off wheels.
15x4 p205/70/15 15x8 5.5 BS (ford8.8) 27.5x8x15 hoosier emod d40
My '74 Duster :
Front :
Keystone Klassic Wheels
14x6 (5 on 4.5 LBP)
Can't remember the backspacing, they stick out about 1.5" further than stock Rallyes
No-name All-Season P185/70/R14's
340 Torsion Bars, Sway Bar
Rear :
14x8 (5 on 4.5 LBP)
Once again, can't remember the B/S, they stick out about 1.5" on the rear too.
28x10-14's
Stock Leafs, Airshocks, B-Body 8-3/4" Rear
When time and money permit it, i'm swapping out the T-Bars for a set of 1.03" Bars (Hotchkis bars).
1973 Plymouth Duster w/ 17" Cragar Eliminator 500's.
17x7 (4.25" BS) w/ 225/45/17 on front and 17x8 (4.5" BS) w/ 255/45/17 rear. Stock suspension and a-body 8.75 rear w/ BBP axles. Front suspension adjusted a little below stock height.
Front: Polished Ansen Sprint 14x6 BFG 225/60-14
Rear: Polished Ansen Sprint 14x7 BFG 245/60-14
1965 DOdge Dart GT:
14 x 6 stock steel wheels with dog dish caps
Front :195/70/14
Rear :215/70/14
Slant 6 .060 over
Front: Aftermarker sway bar, 340 T-bars, Poly bushings,
14x6 195/70/14
REAR: 1973 Duster 340 rear leafs, Spring hangers, shock mounts, Poly bushings, KYB shocks (painted black), 14x6. w/ 215/70/14
Love the 340 springs.. rec using sub frame conectors. nice on the flat roads.. but its so stiff i get twists in the hardtop on inclines like a driveway.. : )
1971 Duster
Front
Wheel Brand- Weld draglites
Size- 15x5
Backspacing- 3
tire size- 195 70
Suspension mods- 73 disc brakes
Rear
Size- 15x12
Backspacing- 7
tire size- 29x14.5
Suspension mod- Mini tubbed, spring relocation kit.gas tank
narrowed 3 inches to keep the tailpipes that
are tied into 3 1/2 " turndowns infront of rear
.I wanted to keep exhaust tips. Quarters were
professionally spread in our shop, and the rear
was moved back 1/2 ".
Car year and model : 1971 dodge dart
Front
Wheel Brand: american muscle. ( mustang knock off)
Size: 17 x 8
Backspacing: 5.72
tire size: 225/50-17
Suspension mods: alter-k-tion and wilwood brakes
Rear
Size: 17 x 8
Backspacing: 5.72
tire size: 275/50-17
Suspension mod: RMS street lynx system. stock wheel tubs
Joe, after showing my Dart the photo of yours, she told me she wants to be just like yours when she grows up (lol).
Front : 15 x 7 Wheel vintiques chrome rally 4.25 backspace
225 / 60 / 15
Rear : 15 x 7 Wheel vintiques chrome rally 4.25 backspace
275 / 60 / 15
70 Dart Swinger
275/60/15 MT Et street radials
15x8.5 Centerline Autodrags 4 7/8 (4.875) Backspace
BBP 8.75 cut to 51" flange to flange, total width drum to drum 56.25". If I did it again, I'd have cut the rear to 50.75 then used spacers to locate the wheels. Easier to add some spacer than take away axle length or add backspace. :) It's REALLY close to the outer wheel lip. Gonna have to roll it.
Home made 3/4" spring relocation kit.
Has maybe 3/8-1/2" on each side of tire in factory wheelwell... TIGHT!
70 Duster: Summit Warrior R/T's all around.
15x4 w/ 1.75" BS - 165R skinnies...
15x8 w/ 4.5" BS - 255/60/15 Radials for now...
Mini-tubbed, but all suspension in stock location, however all converted over to big bolt pattern...
Car year and model - '76 Duster
Front
Wheel Brand - Mopar
Size - 14x4.5
Backspacing
Tire size - 195/75-14
Suspension mods - None
Rear
Wheel Brand - Mopar
Size - 14x4.5
Backspacing
Bad to the bone.
68 dart 440
Front
Wheel Brand - centerline lazer II's
Size - 18x8
tire size 235/40/18
no mods done that would of changed stock fit
Rear
Wheel Brand - Centerline lazer II's
Size 18x9.5
tire size 255/40/18
4.5" backspacing
im very happy with the wheels but will never order from centerline again.
wheels just fit
I have a question. After reading through all the posts, it seems like a wider rim can be used on an unaltered fender well / leaf-spring car when a 18" rim is used, instead of a 17". Am I reading the posts incorrectly?
I'm thinking about going w/ Cragar 397 series wheels in 17"X8" with 4 1/2" back spacing. After reading through the posts, I'm even more lost if they'll fit on my 73 Swinger. My car sits pretty low since adding Hotchkis leafs. I'm thinking 225/50-17 in the front and 245/50-17 in the rear. Any thoughts about fitment issues I might have?
Thanks!
The 17 inch diameter ones fit on mine, without any alterations to the wheelwells or rear springs.
They're not huge, just 8 inches wide in the rear and 7 inches in the front.
The 18 inch ones may have fit, but I didn't want to go any larger than 17.
Did you change your brake setup as well?
I think I'm going to switch into budget mode and just fit the biggest rubber I can on my rally wheels.
I think it's really on the front where it makes a difference. 5.7" BS is about the max you can go before the wheel fits the outer tie rod end. Many 18's will clear the OTRE, allowing greater BS and more tire up front. Probably more critical on Darts / Scamps than Barracudas and Valiants. Out back, I don't think DIA makes much if any difference, you can only squeeze so much in between the inner quarter panel and the leaf spring.
Clair
Thanks!
1965 Dodge Dart GT /6 2BL:
FRONT: 1973 340 Duster T-bars and KYB shocks.
REAR: 1973 340 Duster rear 6-pack springs and hangers. KYB Shocks,
14 x 6 stock steel wheels with dog dish caps and trim rings.
Front :195/70/14
Rear :215/70/14
SBP- 7.25 Rear with stock gears
