Whos running a 5.9L Magnum ?
AdamR
Big Member
Bethel, CT
I found a 93 5.9L magnum cheap locally I may pick up. Let me here your 5.9L combo.
Do you have a gaol in mind?
I'm gonna stay tuned to this one myself. Though my boat is a bitdifferent. It's allways good t read up on whatothers have.
I have a '99 Durango. Leagal limitations apply. AKA Smog pipe test! That thing moves preety good for a heavy ride.
No specific goal. Im thinking cheap headers, RPM intake Hughes whiplash roller and a 750 double pumper.
I'm running one and like it a lot.
I left the shortblock as it was in the Durango.
I put on a Kevko pan, custom hydraulic roller cam, RPM Air Gap, Quickfuel 750 DP, 1-5/8 Hooker Comps through 2.5" X-pipe. Stock rocker gear, Iron Ram heads.
I converted it to LA style serpentine setup and had the Iron Rams drilled for LA intakes.
Times in sig for my full weight bench seat car.
The Iron Rams ported out?
What are your cam specs?
Rear gear and tire size?
Converter stall?
Nice numbers dude.
Thanks man!
My original plan had been to use the stock Magnum heads, but they were cracked.
Iron rams are the base model 1.9 valves, untouched as delivered for $800 a pair (plus drilling for LA intakes, the LA bolt castings were out of stock) ...If I were to do it again, I would have had the heads prepped to take a taller/better/beehive spring, I'm kind of stuck with the 1110s and they really aren't enough for this cam and 6200 RPM through the traps.
Cam is 224/230 .536/.544 (high energy lobes).
Currently 4.11 gear and 26*8" tire. Best time was run with 3.91 and 27" Hoosier Quick Time Pro.
Converter is hard to say. Only footbrakes to about 2000, will go 3500-3800 on the transbrake.
This same combo went a best of 11.88 with a 670 Street Avenger Holley in good air, but a ton of 12.00 and 11.9xs in the heat.
When I was running the Street Avenger, I had $2800 in the motor air cleaner to pan, including headers, gaskets and 5 quarts of Royal Purple. Cheapest 11 second Mopar motor I've seen! ;)
By comparison, the quickfuel was an expensive .18 - LOL!
I don't have the sheets with me, but it made in the vicinity of 335hp at the tires on the dyno.
The car has caltracs and monoleafs and Calvert shocks also. Its a very very streetable combo (except for the gear).
There are some gotchas to the Magnum swap. I'm trying to put together a web page detailing all that stuff, but I pretty much suck at html and don't want to do something generic.
Huzzah! (I need to buy a copy of this pic)
I would really like to see what this combo would do in a more gutted/plastic bucket seat/no back seat/no wiper motor/no heater box type race car.
I'm running a 5.9 Magnum in my car as well. Granted it's not an A body, but still. The engine is a bone stock rotating assembly with stock (and possibly cracked) Magnum heads.
Comp cam (P# 20-746-9) - 216/224, .506/.506, 114 (spec'd for turbo application)
MP springs and retainers
Edelbrock Air-Gap with 1/2" open spacer
Quick Fuel 650 dp (Also tried an Edelbrock 750, but the 650 was better overall)
Summit block hugger headers (1 5/8" primaries, 2 1/2" collector), dual 2.5" with x pipe
LA front cover, water pump, with v-belt drive (custom brackets to run stock Denso alternator)
The car weighs roughly 3000 lbs with me in it. Heavier than most people think, but I haven't tried to lighten it up any, yet.
Stock 98 Dakota R/T with a Shaker hood, gutted cat and a syms box on the back O2 sensor wiring.
Didn't buy it for 1/4 mile. Bought it for hauling my Dart...and ***.
Adam, are you going to run the computer? Overdrive trans?
LX, is an overdrive outa the question? I hear ya on the 4.11 & 26/27 inch tire. I have run that for a while. Limited Hwy. At least w/an O.D. trans, it would calm down to 2.83.
I don't want to hack on the floor to fit an OD trans, plus I got a lot of work in this 904.
PLus I think I'd rather buzz the crap out of the motor than R&R the thing again. ha ha
Stock freebee 99 engine.Knock off air gap,well massaged 750/d.p.Crower single pattern(114 l/c,224 at .050,.491 lift).Stock heads,hooker super comps,3 inch with 2 chamber flows(tooo loud....working on it daily driver(hoping.....).Adam,you thinkin surfin hang ten magnum style?
Running a 5.9L based stroker 408 ci in 74' Duster. Engine has 4" mopar cast crank, K-1 rods, internal balance. CP pistons, 10.5 cr, RHS magnum style iron heads mild port and intake matching, Hughes hydraulic roller lifter cam 236/242 -.559 lift, racer brown roller rockers. Eddy RPM airgap intake w Holley street avenger 870. TTI headers. Engine dyno best 540 ft-lb, 520 hp @ 5900rpm. Engine torque is great and almost flat curve.
Running 727 auto w 3200 rpm convertor and 3.55 suregrip in 8.25 rear.
Tried a year running street tires at 1/8 mile track and couldn't get traction. Last year I got MT drag radials best was 7.99 at 90 mph, but still struggling w 60 ft times.
I wanted the hyd roller lifters and used the original lifters with just a cleanup. really happy with the build and can run 91 pump gas.
d
71 Dart, weight un-known, 95 360, bone stock bottom end, RHS heads, re-ground factory roller from bullet, 477/477, 218/218 on a 112, Summit headers, 650dp, Crosswind RPM, MSD dist., 3.73 gears, 27" MT DR, 11" 2800 PTC converter.
12.5s @ 105 NA, 8.0s @ 85
On a 125 shot. best run backpeddling it. 7.48 @ 94
Never shifted above 5100.
Thanks JD451,i saw the video you posted.I am following your combo after watching the video. Thnks.
72 Duster
weight "Was" 3175# w/o driver.
360 magnum(crate)
Mopar performance 501" / .513" lift cam
Iron ram heads
hooker 1-3/4 headers
holley 750dp
904 3500TA converter
8-3/4 w/ 3.55 sure-grip
ss springs 90/10 50/50 drag shocks
275/60/15 street radials
11.8 @114
Adam,
We are running a 5.9 claiming 335 hp in a 2000 Dak as an I/CM drag car. Running R/T heads with no porting, M1 intake, 750 Holley DP, 10.5 Hoosier slicks, 4.56 8 3/4 with spool, CalTracs, weighing 3430 per IHRA rules. Best run to date was 11.21 with 1.49 60'. Any other questions, PM me and I'll add more.
Bill
67 A-100 "the box" lol 95 360 factory 8.7 comp 55kmi re-ringed and bearing basicly copied the 380HP crate engine, ran 12.70s but its like pushing a peice of plywood in the wind i would think it would run low 12s in a a-body
I have a 5.9 380 crate motor in a 71 Demon street car.
M1 intake
Holley 750 DP
Mopar eletronic dirstributor and box
410 gears
MT drag radials 275 60s
Header & x pipe 3" mufflers and turnouts
3000 converter
run 4.80s at local 100 yard track
Have not had it on a 1/8 or 1/4 mile yet.
5.9 Magnum, stock heads, Mopar dual plane manifold, Hughs roller cam, TTI headers, TKO 500 trans, 3.91 rear. 3700 pound street car, 12.34 @ 112.4 with Nitrous.
92 360 Mag stock bottom end and heads, completely rebuilt
crosswind dual plane
mp dizzy
msd 6 al with blaster coil
650 double pumper
cam 276/498 286/512 112 lsa
double roller chain
hughes single valve springs
904 w/3500 converter, 2 qt extra deep pan, cooler
reverse valve body
3.91 sure grip 742 case
150 shot of gas
hoping for 12.70's off the gas
and 11.60 with the gas in street trim, thru the mufflers
traction permitting of course
I want to spank most stock vettes, camaros and mustangs
I'm running one in basically the same setup as LX guy w/ less cam and w/o the drag race setup.
No healthy times yet. Still working out tuning & tranny issues.
Does a Dak R/T count?
Mostly stock except K&N long tube breather and cone filter, Dynomax cat and cat back duals.
Won't beat any new mustangs, but does pretty good in the 4200 lb CC truck With the 3.92's- Will boil the fairly sticky Hankook 101W's until I let off.
Would do a hell of a lot better in a 1000 lb lighter car with traction!
Bump,X2. UOP made Hot Rod this month.The photo shows that RX transferring well.
