I found this on Craigslist last night and am waiting to hear back from the seller. He says it's internal balance but doesn't say whether it's a cast or forged crank. Also trying to figure out what KB piston he used so that I can figure compression.
1977 Dodge 360 smallblock bored .040" oversize.
All new rings, freeze plugs bearings.
Hughes Engines stroker kit:
Internally balanced.
4.04" Keith Black pistons.
4.00" stoker crank.
Eagle crank and rods.
ARP rod bolts.
Hughes Engines solid lifter camshaft
Intake .543" with 242 duration @ .050"
Exhaust .563" with 248 duration @ .050"
106 degree lobe separation angle
It's a short block only and he's asking $2k for it. I am going to try and look at this after work today. Wanted to know what your thoughts on it and what kind of questions I should have for the seller? Thanks in advance for any help you can provide!!!
4.00" stoker crank.
ARP rod bolts.
