Post Early A-body wheel/tire combos here
porksoda
Clovis,NM
I stole this from another thread on here. I was going to try to make my own list but this list is really well layed out.
Looking for wheel/tire combos on Early A-bodies only.
Maybe this will be sticky worthy :)
Lets keep a running list of wheel and tire combo. Its an often asked question.
Copy and Paste in to your reply
Car year and model
Front
Wheel Brand
Size
Backspacing
tire size
Suspension mods
Rear
Wheel Brand
Size
Backspacing
tire size
Suspension mod
Car year and model: 1964 Plymouth Valiant 100 2dr post sedan
Front
Wheel Brand Stock Steel
Size 5.5 x 14
Backspacing Stock
tire size E70 x 14 (26" Dia.) Firestone Wide-Oval (Belted) Coker Tire
Suspension mods Lowered approx 3" (T-Bars)
Rear
Wheel Brand Wheel Specialties Steelies
Size 7 x 15
Backspacing 4 1/2
tire size F60 x 15 (26" Dia.) Firestone Wide Ovals (Belted) Coker Tire
Suspension mod 2" Lowering Blocks / Front Spring Hangers Flipped
Rickster
Stock 185/80/13, next week the cragars come,will edit pic then
Thanks Moe
Bump back to life!
There has gonna be more people wanting to post up about there tire/wheel combos.
Here here!
I am getting close top changing mine, and am wanting to see what is out there two. Like to see tires that fit without any mods.
65Vsignet and bigall
Did those rear tires and rims fit with out modification????
Thanks!!!!
18x10 and 18x8 26x12x18 rears and 235x40x18s front.
Back spacing rear 6.4 front 6 Car is mini tubed running 73 up front spindles with 11.75 rotor and Wiwood brakes.
hey big al, those 215/65's are a taller sidewall than stock (185/75), aren't they?
i'm hoping i can cram some 225/65's in under the lip of my VC sedan. the higher final drive would be good for highway cruising, and keeping the traction under control at launch.
the biggest i could fit on my first VC sedan was 215/65's, but that was with stock rims widened to 6" on the outer face (outer offset?) with no inset (?). my plan this time is to widen in towards the chassis rail as far as i can go without spring relocation or mini-tubbing . . .
:burnout:
Didnt see 1 picture of a early A body.EARLY a bodies are 60,61.and 62s.Do you want pics of kinda early a bodies?What year pics are you looking for?Mark
:burnout:
From what i can tell 225/65's would fit eeasy coz next time i need tyres that's the size for me.:thumbrig:
Do you want pics of early A bodies?60- 62 or kinda early A bodies?wont bother posting pics unless you want pics of actual EARLY A bodies.Guzzi Mark
By early a-body I am talking about Pre 1967 A body Mopar.
Like this whole Early A-body section is about.
dear me, i hope i haven't offended anyone by posting my Aussie '67 VC (which is based on your '66 Valiant).
i had thought, since it is officially an Australian model that ran mid 1966 > mid 1967 and was replaced with the much larger VE model that i was in a welcoming community . . .
Car year and model
Front
Wheel Brand: Dodge/Mopar
tire size: 205-70-15
Suspension mods: Original
Rear
tire size: 215-70-14
Suspension mod: Original
Wheels: 2006 Dodge Charger aluminum
Car: 65 Barracuda upgraded with 73 duster disc brakes and rear end with large (4.5) bolt pattern, otherwise nothing else has changed
Rear:
17" X 7" . with a 1/4" spacer (with 1/2 " longer studs) for 4 5/8" total offset
225/50-17 tires (stock overall height as 195/75-15)
Front:
17" X 7" with a 1/4" spacer (with 1/2 " longer studs) for 4 5/8" total offset. Had to cut out center to clear to clear rotor and covered hole with a nice chrome cap.
215/55-17 tires ( I know they're taller then the rears but they were cheap!)
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Centerline satin Autodrag 3.5X15 with Michilin XYZ 165SR15's fronts and old satin 15X8 Chevy 2 Centerline Autodrags redrilled to 4 BC with custom centering rings. They are 4 7/8 backspaced so they are super close to the 8 3/4 rear spring. Im gonna need a 1/2 spacer as almost any tire sidewall bulge will hit the spring.. hoping to run a 70 series 255 wide oval tire back there for proper stance. BTW, who make a +1/2" longer 7/16 stud for the 8 3/4? part number?
Australian 1966 VC Valiant. Be nice, she is an early A-body.
New Maxxis MA1's. 185/75's on front, 215/70's on custom 6" rims on the back (sitting nice and snug around 1/4" away from the leaf spring).
