This is a plea for information (help) from anyone who has run an engine with locked out timing (no advance in the distributor.)
Our engine is a low compression /6 engine (9:1) with a mild cam (210/210 degrees of duration at .050"-lift.) It's a race-only engine and is turbocharged; ergo the low compression.
Here's my question:
We plan on running 18 degrees of spark advance.... period. No vacuum or mechanical advance; just a distributor with the mechanical advance plate LOCKED and installled at 18 crankshaft degrees advance...
Is this going to cause the phenomenon known as "starter kick-back" or is 18 degrees not enough to cause that?
We have a sizeable, 600-cold cranking amp battery wired directly to a Mini starter.
It should have lots of cranking RPM, given the low compression ratio...
Still, I have never done this before, and wondered if someone who HAS experience with it, could tell me what we'll be up against with this :locked-plate" setup.
"Kickback," or no????
I can install a distributor with an advance curve to avoid this, if necessary, but would rather not, if I don't have to.
Any information will be appreciated!:blob:
