Wilwood Drum-Disc conversion A-Body
RattyBarracuda
Scott Township (Lackawanna County), PA
Located in 18508
Installed but never used. Never had fluid added. Dynalite conversion
Asking 650$
Will throw in pre-drilled big ball join spindles pictured with brakes for an additional $400.
PM me and we can make a deal.
I'd love to pick them up but having cash flow problems presently. If you still have them in a couple of months I'll drive up and pick them up.
What exactly comes with the kit? Does it require a different master cylinder & proportioning valve? Are the upper control arms included?
Upper control arms are not included.
Without the spindles this is the regular kit from wilwood for converting your front drum setup to disc. It includes the hubs and bearings, rotors, calipers, brake pads and all the hardware to mount them to the stock a-body drum spindles. There are two mounting plates and holes have to be drilled into your stock spindles to mount the caliper bracket to them.
also for sale with these I have a pair of later A-body big ball spindles that are already drilled and setup for the caliper brackets.
As for the master cylinder there is not one included in the kit. wilwood recommends using their master (of course they do) and proportioning valve.
