69 408 valiant ute
340pete
brisbane
this is my 1969 valiant wayfayer ute, was a slant 6 3 speed now a hemi 6 4 speed, converting it to a 408 auto, pete
How did the slant work with the power brake booster in the way? Or did you add that after the engine swap?
great look ride, btw. :thumb Up:.
Boy, that thing looks tough! I like it! I just noticed that it uses the short "4-door" front doors.....interesting.
It's not a problem with 6s if you go the V8 route then you need to change to the offset booster setup (same as on my Wagon) or a remote booster
LOve it, Love it, Love it!!!!! Love those Utes tmm
I know I am going to feel stupid, but are those Cuda taillights?
Would've felt lamer if I had asked if you have to reverse the rotation on the distributor to get it to run correctly down under.....
Anyway you look at it, that is one awesome machine.
no standard tail lights for ute, from 68 ve to 71 vg, got the tubs cut out today to get 12.50 m/ts under, heres some more pics, pete
my brouther came around this morning and put the hand brake cables in, made a brake line up, adjusted the back brakes and bleed them front and back, measured the tail shaft up, 1200 long, measured the tubs up for his son to make, crank is in getting balanced so 2 weeks till the motor will be in, pete
some pics of the 408
a few more pics,
