Now that looked like fun.
Here's a thought..........
Is the year of the block important? If not, look for a 1955 Poly 301........3.91 bore, 3.125 stroke, or at least look for the crank, do a 318 block, custom pistons and have fun.
Just an idea.
Those poly motors are big and heavy. Thanks for the input though. :wink:
That is not entirely true. Some where here at the site I have put next to each other a "LA" shortblock and a '66 poly shortblock. I took pictures to be illustrative on the exact differances of the two.
I'm at work on my I-phone, so forgive me for not finding or repostings the pictures. I'll just restate them here in short.
There is NO size differance between the blocks!
Please read that last sentence again.
LA heads will fit and bolt on the Poly block BUT the Poly blocks water passages will not match the LA head at all.
There are less freeze out plugs on the block. Notably on the front.
The Poly block will only be heavier due to the thicker cylinder walls and extra metal due to the lack of freeze out plugs.
You can swap cranks around between the Poly and LA engines. As said before, the flange at the cranks rear is the issue to contend with per application.
Unless the "301" cube engine was around the corner, I would not search for one. Or the smaller 277 Poly engine.
273 have you looked at any solid rollers for this combo? If I keep it factory bore and stroke run more gear then I want it to be able to scream.![]()
SCCA Solo racing rarely gives you a chance to get out of second. They really like to limit speed. It's more tight and technical racing. Cars like this Mustang would be the competition. Most courses are actually tighter than this.
Fox Mustang Autocross SCCA C Prepared CP - YouTube
That looks like alot of fun. Reminds me of the sand dunes but without the whoops, uphills and drop offs.
News Flash!!!!! I have been over at the Grassrootsmotorsports.com with my build thread and found some info. Most of these guys are tied into the SCCA and here is a quote that I am researching. "I know CPDave here petitioned the SCCA to allow 318's to be substituted for 273's, but I can't remember for what classes. IIRC, they allowed it. He's built a pretty stout '66 Dart with that 318. If you've seen pics of a zebra striped '66 Dart, that's his."
If this is true and they allowed him to run a 318 in the under 5,100cc class then this is a game changer. That would be awesome, because we could build a killer 318 IMO.
Hey Louis
Hey John! Will be xlnt news if you can use a 318. You can make them scream real easy!
