dartcuda1
67 Barracuda 500ci 6sp
Just to let you know,The driveshaft I have came out of my 67 barracuda with a 4sp.It was custom made for the car.I had a 7 1/4 rear that blew up when I was racing a mustang.I put a 8 3/4 rear in and the driveshaft was to long so I had one made. The reason I will part with it I put a T56 in the car and had to get a new one made.So it's yours if you want it.If you have a 8 3/4 rear it will bult right in.Also have a hurst shifter I will have to look but I yhink is with linkage. Mark
When you are done measure the drive shaft.I got one for a A body 4sp you can check out.Living in NJ oyu my be able to come and pick it up.It will be cheap. Mark
