Parting out a complete 1966 Valiant 100 Slant Six
I pm'd you . How about the rear window seal ?
Sorry about that, I did forget to reply...sorry rear window seal was toast. I think you can buy new ones though, I an sure I have seen them on eBay before. Maybe try posting an ad in the "parts wanted" section, somebody may have a spare.
No one makes them yet & They are one year only.
I have searched e-bay high & low .
Thank's for the reply.
If you come across one let me know:burnout:
Dash cluster, 2 plastic cowl plugs, rear view mirror, door strikers, and firewall blower motor mounting plate/ring have been sold.
Hey, any luck on that list of parts??? Just making sure you haven't forgot :)
Yup, I am getting the stuff together for pics, some of the parts you asked about are stored 30 miles away at my dads house, I talked to him today and will have all the stuff here on monday. Then I will shoot you some more info with pics and the condition and we can go from there, thanks for the reminder :D
Here are pics of the parts you asked about. They are not perfect, the lower grille filler has a dent in the middle part but can be fixed, all bolt holes and mounting tabs are good. The center support might have a slight bend or its curved a little? The center grille had some bent fins but have been straightened. no bad dings, mounting tabs are good, one has some scuff cause a mounting stud for the grille had to be cut, no biggie. There is a tiny crack at the botton senter on the underside, no biggoe. All of this stuff can be fixed or improved too. The center grille is tough to find so hopefully you can use it. PM me if these will work for you.
Here is a pic of some stuff I have left yet.
The lower grille filler, the center grille, latch support bracket and right front bumper brackets have all been sold :glasses7:
Still plenty of stuff left :coffee2:
Decent right side arm rest base and soft pad
