Mad Dart
Nothing to see Here!
Well put my trans together last night. Air Checked the clutches on the bench and they
were engaging fine but the front clutch drum is acting weird and sounds like it has an air leak after I assembled the transmission. I had assembled everything but the valve body and decided to air check it again assembled. I can hear the rear clutch engage but the front one sounds like a solid air leak. I already pulled it back apart "whole 5 minutes" So this morning I will be opening up the front clutch and see if a lip seal rolled over........
This is a Video of the Air Check AFTER I pulled it back apart. It did not sound like this on the original bench test only after I installed it in the transmission.......
[ame="http://www.youtube.com/watch?v=QslWqLpxg8Q"]904 air test - YouTube[/ame]
