Installing a Tuff steering wheel, Question
mistreta
I want to put a Grant tuff steering, #846, wheel on my 70 Duster. The wheel has a 1 3/4 in dish. Besides the #3314 adaptor, will I need a spacer to keep the turn signal lever away from the steering wheel.
Thanks
Tony In Mi
Yes you need a spacer. Grant sells one but I think you can also use the factory tuff wheel adapter.
I put a grant tuff wheel (forget the part number) right onto a stock adapter. In my opinion the stock adapter looks tons better then the grant adapter.
I have a stock steering wheel on the Duster now. Is the rim bow you speak of on the set up I have now?, (Floor shift) do I need something else? With this rim bow, I will not need the Grant 3314 adaptor? I want to make sure I have everything I need.
Thank you, I appreciate your help.
