Working in the paint business, I have heard of stories where rags that were soaked in solvent caught fire. Just a possible cause. The most important thing though is that you are safe, and you were there when it happened.How long was the papers in the car and was they stacked up. This is my call
Being a FIre Fighter u see it all the time and if it was hot out side, you moved the enough to get a little more o2 it will happen
Wall wort?
Kind of related to wiring work safety, but once when young I was working under dash and my big class ring shorted to a hot wire. Got a arc burn on my finger, nothing serious but now don't wear ring working on car.
I can't believe nobody mentioned this. What gauge wire were you running current through? Too much electricity through to thin a wire will get stuff hot enough to burn. Quick,fast, and in a hurry.
The wire in question is the OEM wiring. I usually use 14awg wire when I replace wires that were melted.
I am not a virgin when it comes to electrical circuits. Before I retired, I was an electrical engineer.
My main problems is the car does not match the schematics I have and/or the schematics I have are incorrect.
I "car guy" from Mich. showed me a huge scar on his left wrist. He was working on a buddy's car with an alternator (GM) and got his Spidel "twist - o -flex" watch band WELDED TO HIS WRIST as it shorted from the alternator output to ground.
It had to be surgically removed. I'd bet money that was no fun
Just reading this made me cringe....
So what year model is the car and what do you have for diagrams?
71 Duster 318V The car in my picture on the left. A picture of the manuals should also show up.
1. 71 Duster and Valiant Wiring diagram manual I bought off the net.
2. Chiltons---Auto Repair manual 1972-1979
3. Haynes Repair Manual-- Dodge,Plymouth & Chrysler 1971 thru 1989
4. Chiltons Automotive ServICE mANUAL 1971
5. Motor - Vacuum & Wiring Diagrams (for passenger cars (1971))
Hasn't there been another discussion before telling you to get a factory Mopar shop manual for your car or was it someone else? Getting a Mopar factory shop manual will make your life a lot easier.
That should have been "fuse protected"
