360 sb on dyno
mrtillie
Yorkton, Saskatchewan
My 360 street engine video on dyno made 460 hp @ 6100 rpm, 470 ft/lbs @ 4500 rpm Ready and waiting to be installed in my 67 Barracuda.
[ame]http://youtu.be/mPtjoC0V6SU[/ame]
Mine made 407 at the rear wheels, 415 torque you will like that thing on the street.
it does not look like ABS's dyno room to me. I would bet it's in British Columbia. his brother in law's shop?
The YouTube description lists"RHS heads,9:8 to 1 compression, and a 108 lobe center solid cam". Sounds sweet.
Sounds doable. Two others with the same basic builds and a XE275HL made right at 430hp. The cams in the two engines are a bunch softer than the one in this engine.
You're right Rob,that cam hits hard at idle. Guessing 250-260@ .050.
Torque is not high enough in peak number and not low enough in rpm to be a 4" stroke. Sounds beastly tho - that's for sure.
ET slips...man....ET slips..
I agree with this. Gotta love all the dyno numbers love. LOL Saw a mopar forum builders 520hp build run the same as my junk 380hp build at the same weight. dynos are ok and better if they match the track mph. Hope the op will post some track info.
That engine would be not so hard to get there with something as small as a xs282s camshaft.
Or 570hp pushing a 3100# car to 121 mph. Nope.
I have seen engines leave shops and the owners try to feed 500+ hp with a 5/16 line and stock fuel pump. No kidding it runs badly and dies at 4500 in 2nd gear.
I cannot answer your pm.MY pm box is full and I do not know how to trash some. you can contact me on moparts.com
Only running for a few seconds,at a time. Not long enough, to worry.
Or 570hp pushing a 3100# car to 121 mph. Nope..
mine dyno'd 510hp weighs 3100#(with me in it) runs 122-123 in the cool fall air.
