BRog
Member
I noticed some diff fluid leaking down backside of tire - traced it to the inner axle seal. Problem is I can't get old one out. I've tried a pry bar. I tried using the axle as some have suggested, but no luck. Everything I'm doing is just tearing up the inner part of the seal, but the seal itself hasn't moved an inch. I'm thinking someone has replaced this seal before and put some sort of adhesive on it. I need to get it out but don't want to damage anything. Any suggestions? Thanks
