pyrojim
Kurt, you are a huge help. Thank you so much!!!!!
Help. How do I terminate the door seal in the pillar side??
to terminate the seal properly insert a very small piece of foam rubber into the hole then cover it with a thin layer or black RTV and let dry this will keep the seal soft and not ruin its shape :happy1::happy1:
I figure you're probably getting bored in Michigan, so I figured I'd ask this one. I'm just trying to sort out the proper order of putting things together.
Is this the correct path for the headlamp wiring??
Thanks
That's a great idea Kurt! Is that a state inspector or someone the buyers hired? Either way sounds like a pain in the A$@!! But, I wish you all the best of luck with that! I'm happy with the way things are turning out so far, going for side glass and top on Monday. That I'm excited about.
As far as the blower motor/resistor. Brown and dark green coming off the harness go into the resistor, the green wire coming off the blower motor go to the third connector on the resistor? The wiring diagram shows it going to "J" in the bulkhead? Wierd because there is not enough wire and the memory of the wire says resistor. Also coming off the motor is a ground with two ring connectors? Any idea where these ground? Anywhere on the fire wall or dies the second ring go somewhere special?
Thanks Kurt!
I'm going to pm my phone number, if and when you leave Michigan, if you're heading past I'd like to buy you lunch. If you don't pass directly by, I'd be willing to meet somewhere on your way! Thanks again for all the help
Got a quick question. Been looking over your build and also a few other 66 builds. I have one and it's a vert as well. I noticed you have mounts on your trans/driveshaft tunnel. Was this only in console mount/shifted verts? Mine doesn't have them and I wondering why. My vert is a column shifted.... If that make difference?
Yeah. I though about doing something like that. It's the door/rear quarter section.
in the old dodge dealership (Jim Vince Dodge on Fort St formerly called Wyandotte dodge)I worked in from 64 to 67 I did repairs for these vehicles when we put in new seals we never locked down the top or bottom seal (meaning sealed em up tight with anything, got 3 days off for doing it that way %^#$%#^) that seal is just a long inner tube type piece that if you seal the ends would not let the door close correctly by staying inflated. even RTV will be strong enough to stop the door seal acting like it should, we were told at the dealership to either hot weld the end in the center of the tube so either end would let air escape or to use a small dab of glue to do the same. I've tried both ways and the hot iron works more like original but it's a pian in the butt to do without ruining the rubber. So I stick witha dab of superglue and cover it(super glue) with another dab of black weather strip adhesive. plus my door seals get into the correct shape I need a lot sooner than with them sealed.
with all that being said it might have been a/this dealership and the practice not being followed by other dealerships
I have a question for you 66 Dvert!
When you used to work at the dealership between 64 and 67 do you remember how the U-clamps on the exhaust system was bolted? Was the U-bolt end pointing upwards or downwards? Any help would be very appriciated.
BTW, your car looks great and is coming together fine.
thanks
it's getting there. had to make a couple of machines to make parts for me and that sure slowed me down.
ahh to get back to your question. let's say "yes". ok done being a smart a$$ but yes they were Mostly pointed down. depending if you were a short person or a taller person made the difference of the angle. taller = more angled shorter = yup down. the last year I was there I hear they were changing over to a different process so that you could rotate the unibody to get things like that done easier, working in a trench or elevated traversway "sucked". when I got to visit a couple of plants I saw 3 or 4 different ways of installing the same part on different cars. they used pit's trenches, elevates chain ways, rotating platforms and others. it seemed like Jefferson assembly,Dodge truck, Dodge main all did it differently by using different vendors for their machinery. nothing in those plants were ergonomic, just put the darn part on and do it AGAIN all day. whew.
At the dealership if we had to replace or repair the exhaust system we'd always put it down "ish" and have to use a paint marker to daub the nuts "red/orange" color showing that we (the dealership) did it., it was nice working on newer cars since they were not too rusty yet. some of the 60-63's were already rusting away in salty Michigan winters
I think the only one we HAD to do upside down and angled towards the driveshaft was the 67 new yorker/newport extension pipe in front of the muffler so it didn't hit the floor pan dimples for the rear foot well .
then they put me in the sheet metal section, (yahoo a pay raise to $1.21 an hour from $0.97). then Freuhauf trailers called me in to work at their plant in for truck trailers, better pay and $1.25 plus benefits. bought my first "new ish" car,less than 2 year old to me was new (yup a 66 dart convertible/6 auto with only 71 miles on it!!) after that I went to the Chrysler plants.
Thanks Kurt. That was invalueable information. Re the paint markings, were they made for the reason that Chrysler did that at the plant or just something the dealer should do? If you have time, in my thread you can find picture of how the muffler was mounted. On side of the muffler has a cut-out on the oval for some reason. Should that side be towards the frame or the prop.shaft?
BTW, if you need newly chromed letters for your quarter panel 65 dartman has a set in mint condition.
