nm9stheham
FWIW.... if you ever wondered what the voltages at the + and - of a typical ignition coil really look like when running, and why you get those odd 6 to 10v readings on your voltmeter at coil + for example, here are some oscilloscope pix from a running ignition system. An oscilloscope presents what is a real time graphing of voltage versus time on the screen; time runs left to right, and voltage on this pix runs 0 volts at the bottom and 16v at the top.
This is from a /6, stock Chrysler coil and points system, running at idle. The same types of waveforms will be seen with an electronic ECU system and a V8. (And my apologies for the poor pix.)
Pix 1 shows the coil - where it connects to the points. When the point are closed and is shorts the coil - to ground, the voltage is near the bottom or very close to 0 volts. This period of time is the 'dwell' of the points (or ECU). When the points open, that generates the spark from the coil , and the coil - voltage rises up to near 12v system voltage (13v in this case).
Pix 2 shows the coil + voltage. When the points are open, it also shows near to full system voltage. When the points close, then the coil + voltage drops to an intermediate voltage (approx 6V in this case); the exponential slope down to this voltage is the coil charging up for the next spark cycle. If your dwell (the time spent at the lower voltage) is too short, then the exponentially sloping charge is not completed and the spark gets weak.
