No EGR on aftermarket intake manifold
plymouth73
modesto ca
1973 Plymouth scamp 318
I am planning on buying a new intake manifold. Most intakes I see have no EGR port. Will this be a problem on my 318?
I read that without egr valve the engine can knock and ping has anyone encountered this problem do to no EGR valve?
They only ping if it's calibrated leaner because it uses EGR. All you have to do is make the necessary jet changes & it should be no problem.
Unless you need all the smog gear to pass a state inspection, I'd say "good riddance"
