Ouch, I would like to hear either of those in a 273 for a guy wants a smooth idle. The Crane is a hydraulic roller so it's out of the question. The operating range of the last two start turning on at 1800 rpm and with lift approaching and exceeding .500 they aren't very mild cams. The original poster was concerned that the Comp he picked out might be too radical and it was a 212/218-.444-110°
When are you operating the car under 1800 anyway? Never go by those numbers. I'm running a cam that says 3-7k rpm range. Cars is done making power at 5600. Makes over 400 ft/lbs at 2500 rpm. It's funny you believe the rpm range they advertise but not the "mild idle" part?
Lift has very little if anything to do with the cams idle. Duration, yes. LSA even more.
Notice this cam Crower 31240 // 214 int./218 exh @ .050. 0.455 int./0.474 exh. 112LSA has the same exhaust and 2 more intake duration than the cam he was looking at. BUT it has a little more lift and 2 degrees more LSA.
Notice the "mild idle" howards cam. All the big duration is on the exhaust valve, not the intake.
I read were after 5200 rpm and I'm not sure I'll get there so it looks like I'll stick with the lifters, now the only question is how big can you go on stock converters rear gears?
Jake
Posted via Topify using iPhone/iPad
What gear ratio?
You'll want a convertor anyway but 5-10 degrees past stock duration can still run on a stock convertor but again, a custom convertor is the bee's knees.
