That cam should be fine. 4 degrees less intake and 2 degrees more exhaust at .050 than an Isky E-4, which is a great 273 solid cam for the street. I've run 340 cams in 273's and they worked good, you should be where you want to go with that cam. Commando 273's were rated 235 hp. Why did you go hydraulic?
Should be a good cam for you. If you're changing from the stock solid cam to a hydraulic you will need different lifters (of course) and shorter pushrods. tmm
I'm kind of in the same boat with my 273 build. I have a 67 Barracuda Convertible with a 4 speed that I rebuilt in 1995, basically stock using the Comp HE-252-H and it is VERY stock. I'm in the process of pulling the engine for a performance gain but since I use this car in parades I don't want some crazy lopey cam that will not idle and puffs fumes of unburnt fuel into the marching band behind me.
I have read through Tool Man Mike's build thread probably ten times and wanted to do some of the same performance upgrades, but I'm afraid I might wind up with a killer street machine like Mike has which is not suitable for parades and my wife driving it from time to time. I really like the Isky E-4 cam because I want to stay with the solid lifters but it's just a little too wild for what I want to do.
If there was a way to tame the E-4, get it to idle well and still have all the benefits of a great cam, I'd go that route but for my purposes I believe it to be a little too much. If I had more cubes, could run 340 heads (without notching my block) or a higher compression I could probably use the E-4 but I need to find a compromise in between what I'm running now and the E-4.
I have read on this forum the quality of Comp Cams has slipped since I did my first build in 1995, but will probably have to stick with them because they can offer me a solid grind in almost any cam I select.
I went with hydraulic because that is what was in there when i tore it down and figured thats how it came. It was until later after i had ordered it that i saw a bunch of articles about how people dont recommend using them. Is there that much of a difference power wise?
I found a set of adjustable ones at the junkyard and ordered a set of comp 7 3/8(original were about 1/8 bigger) which i figure should be ok since its not a huge lift cam. How different is it from your ISKY and how does that idle for you?
Thanks for the rest of the input guys!!
Jake
I think there are too many variables.
Which heads and how much milling is done or has been done before, adjustable or non adjustable rockers, stock or aftermarket. That's why there isn't a set length called out repeatedly. To measure what length is needed for each build is the best plan.
A lot of issues with idle quality have to do with tuning. What is the timing like in your car? I'd think that E4 would be fairly mild to stock sounding...
An old thread on 273 cams....................
http://www.forabodiesonly.com/mopar/showthread.php?t=225211&highlight=d/dart
The issue with some of the info provided is that advertised duration means nothing. Compare duration at .050 and if possible compare the .050 to .020 specs. LSA also isn't mentioned and make s a huge difference in the way they idle.
For instance advertised 284 and at .050 206, etc..
The cam you typed in the first post is 212/218 duration @ .050. 444 lift. 110LSA
Check out these cams. This is in the realm of what you are looking at. The Howards for example claims "mild idle, good low RPM power"
Crane 699611 // 214 int./222 exh @ .050. 0.488 int./0.509 exh. 112LSA
Crower 31240 // 214 int./218 exh @ .050. 0.455 int./0.474 exh. 112LSA
Howards 711651-10 // 218 int./226 exh @ .050. 0.502 int./0.525 exh lift, 110LSA
Ouch, I would like to hear either of those in a 273 for a guy wants a smooth idle. The Crane is a hydraulic roller so it's out of the question. The operating range of the last two start turning on at 1800 rpm and with lift approaching and exceeding .500 they aren't very mild cams. The original poster was concerned that the Comp he picked out might be too radical and it was a 212/218-.444-110°
