replicaracer43
Grumpy Old Man
- Joined
- Oct 10, 2008
- Messages
- 6,051
- Reaction score
- 7,867
My question to the OP is what exactly IS the budget?
OP has a lot of parts that would already work on either build.
He already has a 360 flywheel, that's the direction I would likely go.
new bolts and resize is pretty close to a new set of rods that a bunch lighter.
Figure out the true budget and work from there. A lot of this stuff will cancel out going either direction, crank vs crank, piston v piston, etc.
The 268 is going to be a puppy dog in a 408" engine.
Ok, so since we're talking budget.
What if I said the stroker is only a little less than 25% more than the 360 build?
That's with the parts I listed.
I think for the current gearing and tire size, the stroker makes more sense! What do you guys think??
Brian
At this point, if we deduct the cost of a machined 360 crank outright, and resizing the stock rods with bolts the Scat 9000 series crank and Ibeam rods are about 850.00 more.
The heads will be stock 360 heads, with 11/32 valves and guides, 1.94 x 1.60 with no port work...not in the budget.
Brian
Joey doesn't care how much power the engine actually makes...I think he just wants it to run good and be very drivable...like driving to MATS and back and racing it while he's there.
Brian
What kind of power do you think that will make?
With some KB356 hypers or some simple Ross forged slugs?
How much power you trying to make with $2550+ in your heads?
Why not just run Brian's RHS heads and save at least $1,000?
That's another problem
Some guys like myself just want some extra "grunt" around town or when he's trying to pull a stump across a few acres.
Different uses of the motor will give you different budgets
I'm also building a torquey "work truck" motor not a quarter-miler.
I'm with flyfish on this one. Ok, for a (little more) scat crank and stroker pistons. So NOW anyone will tell you for a (little more) than restoring the old rods, scat I-beams. Your not going to put all these good expensive parts together with cheap bearings and rings are you? NO! for a (little more) good ones. NOW this must be internally balanced ? Only $200-250 labor plus malery - mine used near $100 worth (its expensive). NOW you must replace your externally balanced flywheel and harmonic balancer for internally balanced? NOW for a (little more) a true roller timing chane and gears? For a (little more) a high volume oil pump? NOW to protect this big investment for a (little more) an extra capacity oil pan? Oil pick up sold separately (I think you're getting the hang of it now!?) For a little bit more. NOW you do need gaskets and sealer to hold it together. hold the fort here! I'm putting the carriage before the horse. first we need to hot tank the block, deck the block, bore the block prepped with freeze plugs, cam bearings, and oil pump rod bushing. Now where was I ? oh yeah, you want the ARP bolts to hold the heads on this beast you're building ? when do I need to start on the heads and if the valves are seating properly, and the springs, and good lord knows what? this is just going to be a simple rebuild and make a stroker," no big deal!" lol ask me how I know !
Well if joey got a free machine shop and was born knowing how to use it, and given thousands of dollars in stroker parts - i could see how he could make a comment like that. I was just illustrating that the "just a little bit more" parts ad up. AGREED - To think a little bit more for stroker crank & pistons is good planning? From my experience it's delusional.Sounds like poor planning on the builders part here...Joey doesn't have that problem because I'm the builder...LOL!
If you can find the extra $800 then go the stroke.
Jamie
a stoker will be like $8,000 not $800
look at the lists above
maybe $4k just in top end alone
