Until you take it to the sand blaster...I see lots of potential rust problems in the structural areas. Good Luck
Check my build thread and you will see what you are in for with the rear window channel.
That support in the trunk looks like factory crappy welding to me. Have seen that many times. Yours is savable but its gonna take some fab work.![]()
let me make you feel better about your rust....heres mine.... and theres alot more....so now you should feel alot better!
I am following your build, while I don't have much thin metal experience I do have a fair amount of welding background and what I think is the basic amount of metal fab skill not to absolutely destroy the thing.
I am also following your situation. I am afraid that is what mine looks like under the cap, however my perches look semi ok.
I know this isn't going to be done for a while, I have already sat on it for ten years so it is what it is. I have gone back and forth on selling it and buying something built already, but I want this one to be mine not someone else's car. If it take ten more years it takes ten more years.
As far as the statement of "do it my way",,,,, rock on!!!!!! That's the part of this hobby I really enjoy, making it my own!!!
cuda sitting in the garage isnt hurting anything, just gaining value....better than stocks or bonds....
its two bolts that attach to each fender and then a center bracket that goes to the radiator support. The hole for the bracket can be seen in the picture provided by ggt1_02I was just wondering because I purchased a 1968 Barracuda already partially disassembled with nothing labeled. What holds the valance on? I need to locate the fasteners and can't seem to find any reference to how the front clip is attached.
Thank you that would be amazingMine is disassembled at the moment, I can try to get some pictures today that will give you an idea
[/QUOTE]
