So, Had to bring this to a new thread as I jumped someone else's thread inadvertently.
75 Dodge Dart
Turn Signals, Brake Lights, and Tail Lights all work perfectly.
EXCEPT, turn signal lever would not hold in detent on left turn.
Pulled the Steering wheel and found the TS cam had one of the detent clips broken.
Replaced the broken TS Cam with Dorman part.
Now all lights work normally EXCEPT I have no brake lights.
Good news is TS will hold in detent on left or right turn.
Further investigation and great help from another member found the problem is with the Dorman cam.
The Brake light circuit does go through the turn signal switch since it is a single lamp for brake, turn, tail.
The poor fabrication does not make contact correctly to allow the brake circuit to complete.
Tonight, I will buy another Dorman cam as a quick fix while I wait for the new complete turn signal to arrive.
75 Dodge Dart
