Valves springs for a 340?
694spd
Upstate NY
I need to buy a new set of valve springs for my 340. I just looking for a stock replacement set that has spring rates similar to the original factory ones had. Any recommendations?
I would probably get some from Comp Cams, not sure on a part #, other will chime in :glasses7:
or trick flow 16901-16
I think it's the same spring and a few $'s less. Someone on this forum pointed out the TF springs being the same comp number with a 16 in front for std springs.
All listed, Single-Coil with Damper
Mopar Performance #4120249 {Stock 340 Replacement w/.206" Coil-Wire}
#90 lbs. @ 1.68"
#230 lbs. @ 1.27"
Mopar Performance #5249847 {340 XHP}
#103 lbs. @ 1.68"
#260 lbs. @ 1.20"
Compu-Cams #901
#101 lbs. @ 1.65"
#242 lbs. @ 1.25"
Hughes #1110
#120 lbs. @ 1.66"
#280 lbs. @ 1.21"
Edelbrock #5877
#90 lbs. @ 1.65"
#240 lbs. @ 1.25"
Trick-Flow #16901
#101 lbs. @ 1.65
#242 lbs. @ 1.25"
Crower #68305X1
#95 lbs. @ 1.65"
#250 lbs. @ 1.20"
Lunati #73084
#119 lbs. @ 1.75"
#246 lbs. @ 1.25"
Crane #99835
#90 lbs. @ 1.65"
#280 lbs. @ 1.15"
Howards #98412
#120 lbs. @ 1.68"
#295 lbs. @ 1.17"
Schneider #68044
#125 lbs. @ 1.65"
#300 lbs. @ 1.15"
#90 lbs. @ 1.68"
#230 lbs. @ 1.27"
#103 lbs. @ 1.68"
#260 lbs. @ 1.20"
Compu-Cams #901
#101 lbs. @ 1.65"
#242 lbs. @ 1.25"
Hughes #1110
#120 lbs. @ 1.66"
#280 lbs. @ 1.21"
Edelbrock #5877
#90 lbs. @ 1.65"
#240 lbs. @ 1.25"
Trick-Flow #16901
#101 lbs. @ 1.65
#242 lbs. @ 1.25"
Speed Pro #VS-678
#91 lbs. @ 1.65"
#231 lbs. @ 1.22"
Crower #68305X1
#95 lbs. @ 1.65"
#250 lbs. @ 1.20"
Lunati #73084
#119 lbs. @ 1.75"
#246 lbs. @ 1.25"
Crane #99835
#90 lbs. @ 1.65"
#280 lbs. @ 1.15"
Howards #98412
#120 lbs. @ 1.68"
#295 lbs. @ 1.17"
Schneider #68044
#125 lbs. @ 1.65"
#300 lbs. @ 1.15"
These Single-Coil Valve Springs are recommended for 'stock' 340 Replacements.
Thanks for all of the info. This will make my shopping a lot easier....
One more to add >
Speed Pro #VS-678
Single Coil w/Damper
#91 lbs. @ 1.65" ..... {#89 lbs. @ 1.66"}
#231 lbs. @ 1.22" ... {#251 lbs. @ 1.17"}
Spring Height ..... 1.940" {Fully Open}
Spring Width ...... 1.494" {O.D.}
Spring Width ...... 1.080" {I.D.}
Coils ................. 5.6
Coil Width ......... .207"
Max Compressed. 1.100"
Same here on the comp cams #901 springs. They have just a little more seat pressure ( 10 lbs or so ). Which I think they needed from the factory to help control the valves a little better at 6000 rpm.
