Hey everyone,
I'm hoping I can get some insight and ideas as to how to fix my currently not starting engine.
1970 Dart, automatic, slant 6 225
A couple days ago, I was driving to work and stopped by a gas station real quick before I got to work. When I got back out and tried to start it, I got absolutely nothing. Tried putting it in neutral as sometimes the safety switch or linkage doesn't always end up in the right place and still nothing. Ended up trying to get a jump from another car and I could get a little hum when I tried to start it up. Replaced the battery and as soon as I got the new one wired in, it would turn the starter and get things on the way to starting but it wouldn't ever turn over. I was luckily able to get it to do a compression start and got it out of the gas station and home. It was able to do this a few more times before I had a chance to get in and take a look at what was wrong and each time once it started running, it would be just as it was before the battery went kaput.
Now unfortunately, I can't even get it to do a compression start. So far, I have replaced the battery (problem started around this time), ignition relay, ignition coil, distributor cap, rotor, spark plug wires, and spark plugs. I do get good spark on the points when I manually close them so I don't think it's an issue with the distributor.
She's still pushing gas into the carb and butterfly valve is still operating on it.
So before I try and replace the starter, does anyone else have any ideas?
