roccodart440
- Joined
- Apr 19, 2010
- Messages
- 6,807
- Reaction score
- 3,590
my engine came of the dyno peaking at 420 HP and 470 ft.lbs of torque
What RPM did it make that torque?
14.0 I think you might find out that getting down the track ain't quite as easy as it looks.
12.50 with the 3.23 once it's sorted out. 11.90's if you get a 3 to 4k verter
That was a good day. Let me ask was that the cars first time out,your first time down a track,or both? This looks to be a first for the OP and the car. And thats where it really helps to have a mentor. Good trusted advice goes a long way in this sport. Way back in the 80s I took an A/A altered out to a track rental day. I had been low 11s in my door car. But the bantam was different. Nostalgia car,100"w/b,crank 24" off the ground,alky burning injected hemi,clutchflite,hand brake and parachute. And a full /15 firesuit. Nobody i knew had run any of this stuff before,myselt included. The first time the car moved under power was a high 11. 6 passes later i had my license and a 9.0@150 timeslip. The hardest parts,(besides the clutch pedal)was the burnout and backing up. The biggest help was that it was a rental day. That is the way to go for beginners. That was a good day.I can tell you that my car first time out went 12.24 and later the same day went 11.74, . 76 etc.
Changes to car? shift light and limiter settings.
Basically all driving changes.
A 1/2 second difference in ET. Just driver error.
With a 7.25 rear end you will not make it out of the staging lane , diff will grenade , at least that's what happened with mine .
I know nothing about converters
other then that everyone says "don't buy and off the shelf unit"
but I just don't want to fork out the money for a custom build unit
Mine is pretty close to that 445 ft lbs @ 4400 423 hp @ 6100 , but that was with 9.9 compression ratio open chamber heads , heads were cut 60 thou so now closed chamber 55 cc 11.3 compression , was to cheap to pull and run on the dyno .I'm planning on babying the 7 1/4 until I get the 8 3/4 in over the winter
I got a chance to look at those numbers today,
there is 440 ft.lbs. by 2900 RPM but only 245 HP
torque peaks at 470, right at 4000 RPM and 360 HP
then torque starts to drop, and HP keeps rising
at 5450 she is making only 406 ft.lbs. and 423 HP
15 sec @ 109. should have invested the money into 8 3/4 and tires 1st. lol
