Another dumb question.. Bronze drive gear
iw378
Suisun City, Ca
When using a roller cam on a la 360 do I have to use a bronze oil pump driveshaft ??
If the cam has a steel gear, use a bronze or plastic distributor gear.
Some steel cams have pressed on cast iron gears and some roller cams are all cast iron. So you need to know what you have.
I didn't on my 408. I used the Mopar performance steel one. I think part number P3690715 which has hardened tip and pinned drive gear.
shaft doesnt matter, its the gear...billet steel rollers usually require a bronze gear pinned to steel shaft. Iron to Iron on a regular or iron geared roller
As already mentioned, it depends on the gear on the cam. Crane makes a coated steel gear that is designed to run on a steel geared camshaft. From my understanding they have been making them for other makes for years. I went with the bronze gear on my build, not enough people running the Crane gear in Mopars for me to try it.
Comp cams site shows a bronze gear is needed. I don't have a shaft to look at right now. the oem gear is pressed on ?
If you run a HV or HP oil pump, it is recommended to use the stronger gear available from MP with a larger diameter shaft....
