Furthermore, different carbs have different requirements as to the total travel. With the pedal end engaged, the exposed portion of the inner cable differs to compensate. If you happen to chose the wrong cable, and it is too short, it will not fully open the throttle. Or worse if you set it to fully open the secondaries, it may not return to idle. Moving the anchor will not fix this. So when shopping, you will need to know how much cable exposure or rather, travel, you need.
