[WANTED] Wanted 67-69 a body buckets
Hello. I just got a 68 notch back this past weekend and I'm parting it out. Somebody recovered them so I'm a little concern about the overall condition of them. The set tracks seem to be in good condition but I should know more about them this weekend when I can really look at them closer. I'm in Simi Valley so I'm not that far away so it would save money on shipping. Thanks, Troy
Pre 67 has totally different floor so seat tracks are also totally different. You will need correct seat tracks for your year model. If you want to add 3 point seat belts you will need 68 or later buckets that have latches on the seat backs.
As stated the seat tracks are different, but 66 buckets are the same seat as 67.
Not exactly the same. The seat back frames in a 66 are a bit taller than the later.
Upper member of that frame was modified for headrests 67 up.
