Recommend a Harmonic Balancer internally balanced
duster1970
Active Member
Madisonville, TN
Planning a 416 build and trying to decide on a harmonic balancer. Anyone have a favorite or least favorite? This will be an internally balanced combination. Thanks in advance.
I purchased the Summit harmonic damper, part number SUM-163273. I haven't run it yet, but there are reviews up on it. I have no need to run a SFI 18.1 $300+ damper.
Here's the link.
http://www.summitracing.com/parts/sum-163273
Of course, mine is "just a 318, with the 3.31 stroke," and since you're running a 4" stroke I don't imagine that you'd be winding it as high as a stock stroke 318/340, or even 360...
I won't use any stock type, non-SFI one again. They're all junk and slip. The SFI ones are tested and tend to not have problems. Have a $75 balancer cost you $2500 in a blown engine and you'll realize how stupid not spending that extra $225 is...
No reason to skimp on this with an elastomer style damper.
Use either a Fluidamper or the Innovaters West.
Rubber band style dampers are obsolete unless you can build your own. And, you have the ability to test and develop a damper.
Yes, there are many in use. They were and are used by OEM's. It's because they do a reasonable job, across a relatively narrow RPM, FOR THE LEAST AMOUNT OF MONEY AN OEM IS WILLING TO SPEND.
I ran a crappy CAT fluid damper and it ran great. That was a hulk of a damper.
Those are not bad, chink things.
The biggest issue with offshore things like this (any part for that matter) is that you MUST verify everything dimensionally. I have seen some with with .007 press fit and some that were .004 loose. So from bash it on tight to fitting like socks on a rooster.
You have to measure everything.
Check out ATI, can't be beat but they're pricey. I use one on my 2500cc ministock motor and regularly turn 8000 RPMs on the track. In three years since I installed it, I see next to no bearing wear when I do an end of season tear down.
That Jeg's unit looks exactly like the Pioneer brand I use, except mine came clear-coated. Very likely relabeled for them.
yes...the one I got is clear coat ...and i believe it is the pioneer balancer
