Ohio66Cuda
Car 66 Barracuda, 360, auto
I was trying to solve a problem with a non functioning temp gauge. In the process of looking for connection problems I removed the gauge cluster. After finding nothing I attempted to put everything back but shorted the ignition switch (didn't disconnect the battery). Snap, crackle and smoke was the result. I saw smoke from under the dash and from the engine compartment. I know that now nothing works, lights horn etc.
1) I do have a wiring diagram but I'm not sure where to start.
2) Should I think about removing the bulkhead disconnect from the engine side?
3) If I do remove all the connections from the engine side, will the compartment side come away? Right now the compartment side is nearly impossible to look at or work on due to its location and heater/ac ductwork in the way.
Any guidance on this will be much appreciated.
